HX One on top an amp on stage
HX ONE
Singular Sounds
HX ONE
HX® One is a powerful stereo effect pedal in an ultra-compact enclose that easily fits onto any pedalboard. It features intuitive controls, 250+ effects taken from HX family processors, a unique Flux Controller, a jack for connecting an optional expression pedal or two footswitches, adjustable input impedance, MIDI capabilities, and a choice of true or buffered DSP bypass.
Explore Features
  • Outline graphic of a chip BEHAVIORAL MODELING
  • Outline graphic of hand holding a pedal ULTRA-COMPACT
  • Outline graphic of a light bulb INTERACTION
  • Outline graphic of a flux capacitor FLUX CONTROLLER
  • Omega letter ADJUSTABLE INPUT IMPEDANCE
  • Outline graphic of expression pedal EXTERNAL CONTROL
  • Outline graphic of MIDI input MIDI CAPABILITIES
  • Outline graphic of a circle with an arrow curving around the top BYPASS OPTIONS
  • USB graphic USB
  • Plus Minus DC power graphic DC POWER
CLICK TO EXPLORE
Front of HX One Back of HX One Side of HX One Side of HX One
Front of HX One
DISPLAY
Press the HOME button to view the currently selected effect and its three primary parameters on the OLED display in the Home View. Additional views supporting tasks such as loading or saving presets and configuring controller and device settings are also available.
KNOBS 1-3
Turn the three knobs on the top row to adjust the corresponding parameters shown in the display. Press the knob to reset any parameter to its default value. Use the < and > PAGE buttons [4] to access additional pages of parameters.
SHORTCUT: Press the knob to toggle the value between ms/Hz and note divisions (1/4-note, dotted 1/8-note, etc.) when setting time-based parameters such as delay time and modulation speed.
EFFECT
Turn this knob to scroll through the complete list of effects and load the one you want. To find a specific effect more easily, press and hold the knob while turning it to choose a category from the Effects Carousel, then release the knob to select that category. Press and release the knob again to display the current category’s Effects list. Press and hold the knob again to enter the Settings View, where you can edit the Input Gate, Bypass Type, and other global and per-preset settings.
< PAGE >
When the selected effect has more than one page of parameters, arrows appear at the left and/or right of the OLED display. Press either the < or the > button to view the additional parameters.
HOME | SAVE
If you ever get lost, press this button to return the Display to the Home View. Press and hold the button to enter the Preset Save View.
ON
Press the footswitch to enable or bypass the currently selected effect. The On LED lights when the effect is enabled.
TAP | FLUX
Press TAP two or more times to set the BPM (beats per minute) of any delay, modulation, or other tempo-based effect.
Press TAP once to restart any LFO-based modulation effect from the start of its cycle.
  • DISPLAY
  • KNOBS 1-3
  • EFFECT
  • < PAGE >
  • HOME | SAVE
  • ON
  • TAP | FLUX
Back of HX One
INPUT L/MONO, RIGHT
Use standard 1/4" cables to connect your guitar, bass guitar, or mono pedals to the L/MONO input. Connect stereo pedals, keyboards, synths, or modelers to both the L/MONO and RIGHT inputs.
OUTPUT L/MONO, RIGHT
Use standard 1/4" cables to connect to your guitar amp or other pedals. When connecting to a mono pedal or single amp, use only the L/MONO 1/4" jack.
DC IN
Connect the included Line 6 power adapter (9VDC, center-negative, 2.1mm center diameter, 500mA) here to power HX One. Disconnect the adapter to power down HX One. Many third-party power supplies may also be used.
USB
Use the USB jack to connect to your Mac® or PC to use the free Line 6 HX One Librarian application for preset and settings backup/restore, and the Line 6 Central application for updating to the latest firmware (available from line6.com/software). HX One also supports USB MIDI control from your MIDI/DAW applications. The maximum recommended length for the USB cable is 6.5'/2m (cable not included).
  • INPUT L/MONO, RIGHT
  • OUTPUT L/MONO, RIGHT
  • DC IN
  • USB
Side of HX One
MIDI IN, OUT/THRU
Connect the HX One hardware to your MIDI gear to receive program change and continuous controller messages, and input MIDI Clock.
  • MIDI IN, OUT/THRU
Side of HX One
EXP PEDAL | FS 3/4
Connect an expression pedal (using a TS cable) or dual footswitch (with a TRS connector) to control assigned effect parameters.
  • EXP PEDAL | FS 3/4
FLUX CONTROL
HARMONY DELAY WITH FLUX
GANYMEDE WITH FLUX CONTROL
ALPACA ROUGE WITH FLUX CONTROL
145 ROTARY WITH FLUX CONTROL
PITCH WHAM WITH FLUX CONTROL
BASS GUITAR
GRAY FLANGER
HEIR APPARENT
PEBBLE PHASER
60s BIAS TREM
MINOTAUR
SIGN UP TO LEARN MORE
MANUALS
Mac is a trademark of Apple Inc., registered in the U.S. and other countries and regions.
