Pro features and tones in a stage-ready package. It's the ultimate multi-effects pedal, complete direct PA solution, and guitar recording workshorse in the studio.
Pro features and tones in a stage-ready package. It's the ultimate multi-effects pedal, powerhouse preamp, direct PA solution, and recording studio miracle.
Compact and powerful, POD Studio GX combines the stunning POD Farm plug-in with a rock-solid USB interface for a straightforward and no-nonsense recording experience.
Ultra-pro 24-bit/96kHz recording interface features 8 I/O with 8 dedicated preamps, the best dynamic range (over 100 dB signal-to-noise) and GearBox software boasting legendary POD tones for guitar, bass, vocals and crucial studio effects.
Best of both worlds: 37-note velocity-sensitive MIDI controller with increased tweakability and super-quiet recording interface with stereo preamps, legendary POD tone and ToneDirect monitoring virtually eliminating latency. Versatility squared.
Inspiration is spontaneous, and BackTrack + Mic is your instant replay button. Capture everything you play, sing or hear in stunning audio without ever hitting record.
Spider Valve is the result of a groundbreaking collaboration between Line 6 and Bogner Amplification, fusing the versatility of modeling with the performance and feel of a world-class tube amplifier.
When only a wall of sound will do, Line 6 cabinets are the perfect companions for Line 6 guitar and bass amps including Spider Valve, LowDown, HD 147 and Vetta II HD.
Custom-crafted, classic style, solid body that reproduces the sounds of classic 6- and 12-string electric and acoustic guitars, plus resonator, banjo, and electric sitar.
Carved top, high quality solid body that reproduces the sounds of classic 6- and 12-string electric and acoustic guitars, plus resonator, banjo, and electric sitar.
16 models of the finest acoustic instruments on the planet with the push of a button. You can easily access jumbos, 12-strings, or even a nylon string classical.
A comprehensive collection of classic and modern stompbox distortions, delays, reverbs, mods, filters and a looper all stuffed into one super-heavy-duty stompbox.
Based on the award-winning DL4 Delay Modeler, Echo Park is loaded with stunning Analog, Tape and Digital Delays in variable delay patterns like Slap, Ping Pong, Swell and Sweep.
This little miracle features 11 must-have reverb models including everything from classic guitar amp-style spring reverb to dreamy, high-end studio favorites.
Boasting truly orbital tones, Space Chorus features three models based on brilliant vintage and modern analog effects with adjustable Speed, Color and Depth.
Roto-Machine offers huge, three-dimensional rotating speaker sounds ranging from dreamy clean to swirling overdrive. These signature sounds were available only from the originalsÑuntil now!
Based on the Line 6 arsenal of power-tube overdrive models, Crunchtone features warm, full-bodied overdrive in three juicy models ideal for fuzzed-out blues and rock.
Award-winning Reason version 4 plus all four hypersampled ReFills, including Reason Drum Kits 2, Reason Pianos, Abbey Road Keyboards and Reason Electric Bass, for the ultimate all-in-one music production environment.
All four hypersampled ReFills for Reason version 4, including Reason Drum Kits 2, Reason Pianos, Abbey Road Keyboards and Reason Electric Bass, providing stunning, lifelike sounds for your music.
Whether you’re recording or mixing your music, great tone is essential. With the new GearBox Plug-in, it’s easier than ever to give your songs that professional, polished, high-end sound.
Get instant access to models of an incredible selection of vintage and modern gear just the way you want it as a plug-in.
With Line 6’s exclusive ToneDirect monitoring, you can enjoy killer tone with near-zero latency you don’t have to sacrifice killer feel, dynamics and responsiveness.
With the GearBox Plug-in, every sound you need is ready to go at a moment’s notice.
There are two different GearBox Plug-in Bundles to fit your needs.
Already own one of these? Use the built-in tone of your PODxt, POD X3, TonePort or GuitarPort as a plug-in! Purchase GearBox Plug-In in the Line 6 Store now. Just a download away.
